10.06.2008, 09:51 PM
Not too bad, but if you are having something made, why not go for the whole shabangabang?
The camber w/ those would be easy to measure w/ a RPM gauge, but I'm not sure how you are measuring the toe. Maybe I'm missing something. I can never eyeball toe right.
The ways I've seen it done is to have a plate mount on top w/ degree marks that line up to the lower vertical plate. It would actually be nice if there was a low cost option, reg setups stations are fairly expensive for just some alu plates. They are very nice to have tho.
