10.06.2008, 09:57 PM
The idea is to just measure the distance across the car from the front to front and the rear top rear of the plates - In addition you need the distance of the front of one plate to the center line of the car. The rest is just trig to calc the toe on the left and right - I can provide the math and I'm sure BrianG could convert into a script easy enough.
The idea was to keep it cheap and combine with the RPM camber gauge for a budget solution...
Would you pay $20 for a set?
