10.08.2008, 09:41 PM
Originally Posted by sjcrss View Post
Im not sure of the screw length, as for i put them in, and cut them to length, then sanded then flush on the inside, as for the cup i used a Onfa hyper 7 diff cup assembly, and the modded ring gear is after the teeth have been removed, i think its gonna work, just got to redo the shafts is all....it's very strong and wasn't to hard to do....once i get all the dimensions for the shafts, I'll add them to the sketch and post them here as well...
That clears up a few questions. Can you assemble the input shaft and the center diff assy into the back section of the trans case and snap a pic from the side? Something like this:
Just want to see how well the gears line up. If your modded ring gear is below the level of the input gear, the idler will not contact it. I had issues with the savage cup and my adapter in that respect. I could reduce the thickness of the adapter and try again.
