10.09.2008, 01:12 AM
8000 x 12c = 96 amps you can pull safely, if you trust the manufacturers C # should be fine LOL (check people eagle trees running the same system around here for peaks and variances ) I run 150 amp (30c 5ah) and havent had an issue since I went higher current. JMO
