10.09.2008, 01:18 AM
This is true, when I set my clutch up (that george16 is getting) I used a clip to hold it on... It only took one shim behind the clutch bell to give correct clearance b/t the flywheel and the bell. Might save you some time to use the clip, worked fine for me and never fell off.
