phatmonk
RC carbon junkie
phatmonk's Avatar
10.09.2008, 09:09 PM
I actualy used a circle cutter for cutting holes in lexan and cut 4 circles out of the aluminum tape stuck them together used that same cutter to cut a small hole for where the bearing is in the center.Then cut the top of the circle off where the wires come out.So far it hasnt come loose but its easy enough to make another.It also atracts dust to the adhesive.
