brushlessboy16
brushlessboy16's Avatar
10.10.2008, 11:17 AM
Oh darn they found their way to the garbage can...
thats not even funny.
Anyways-
Just did a shakedown run. Truck is solid but somethings need to be tweaked... like the center diff fluid... if i gun it the front wheels do indeed come up. but the tires look like pizza cutters.
Then i had a pinion work itself loose, luckily it stayed on the truck
-Motor only got to 130 degrees geared for 46mph... The fan on the MMM came on alot.(w00t its still alive)*mods- switch removal, teflon washer, custom foam inserts.
- I eventually got used to driving and had to use a light trigger finger.. the truck is very easy to correct in the air.. it does get a little torque roll-probably due to the giant spur gear.
Because of the diff unloading and me trying to keep this set of tires. i never did any speed runs, just a little bashing- the suspension is soo plush.. a little too plush on the rear.
Lost Parts- One kingpin screw
Loose parts- Pinion setscrew, right front wheel nut,
Things to fix- Antenna placement
