Thread: I'm pissed!
RBMike
RBMike's Avatar
10.10.2008, 01:05 PM
Originally Posted by Unsullied_Spy View Post
Can't the dirt still work it's way in there? I'm using an RC-M heatsink clamp (probably use some aluminum foil between the motor and transmission) and a trimmed washer on mine. I E-Mailed Medusa and they suggested covering the holes when using it offroad.
You definitely get what you paid for, Neus are certainly worth the money. I haven't gotten my Medusa running (MM had some issues with it we couldn't work out over E-Mails so I sent it back to CC) but I have looked it over thoroughly and the initial quality is impressive.
I also have a neu with the RCM covers on it & it actually gets more dirt in it than the Medusa with the wide tape over the ends. I peel it off once in a while & blow it out with air & less comes out than out of the Neu. The Medusa is holding up well & has many hours on it. I think neu's are the best but for the money I have no complaints about the Medusa & it is lighter than the Nue. Where you at in Montana?
