Thread: emax trans case
Promod
11.04.2005, 10:19 PM
After playing with this tranny case and having it together and apart a few hundred times. I just can't seem to get it to stop binding. The lower shaft and idler gear are smooth after grinding were the idler gear hit the FLM case. But the input shaft (top shaft) has some major binding. The single speed cover dosen't fit right on the FLM case. At the top of the case is were it is most out of alignment.
Maybe this is a bad case, not sure. But it is unusable the way it is now. I will try and fool with it more tomorrow.
Thank you,
Promod
