ffactory666
10.10.2008, 09:58 PM
Well finally got it started
This time unlike my X2 conversion i started straight off with the center diff , motor mount and servo tray etc . Next will be the battery tray .
Chose this route as that's the parts that need modding to get them to fit , so the rest of the buggy will be the standard build and should go smoothly without having to take things apart .
First couple pics are off the center diff and motor mount .
Thanks to Ty the HB team driver who test fitted the truggies center diff mounts to the D8 for me before the buggy was released to make sure they fit as you can only get a brushless motor mount for the truggy .
So in went the RCM motor mount and truggy front center diff mount . The diff fits perfect and tying them together is a Kingheadz alloy Lightining center diff top plate , no modding needed .
The only thing i changed from the box set up was going to 7000wt oil in the center diff instead of 4000wt as we know the torque of the brushless motor usualy requires this from the get go.
ID:	5600   Click image for larger version
