Ryu James
Ryu James's Avatar
10.10.2008, 10:03 PM
so i cut off the switch and wired up the red and black together. the MMM fired right up. been running fine now. i bet my first MMM was the same problem. it had the exact same symptoms. too bad i already sent it in. so now i think i have a good system to make a MMM last. remove fan, cut out casing to expose heatsink for cooling, and install quality switch (or remove altogether). these 3 steps seem to prove helpful and having a MMM that will run trouble free. so far......
time will tell.
Jammin SCRT10 Neu 1512 1y
