10.10.2008, 10:49 PM
Excerpt from http://www.batteryuniversity.com:
Originally Posted by batteryuniversity.com
-The time at which the battery stays at 4.20/cell should be as short as possible. Prolonged high voltage promotes corrosion, especially at elevated temperatures. Spinel is less sensitive to high voltage.
So, keeping the cell at half charge ensures the voltage to be at the nominal value. I'm sure you could discharge as needed until the open-circuit resting voltage is ~3.7v...
