Thread: Melted Ground
10.10.2008, 11:21 PM
Assuming that everthing was working fine, the only thing I can think of is if the main ground connection is not perfect (bad solder joint, loose connector, dirt connector, etc), the system will draw current through whatever ground it can. And since the LVC ground wire is small, it can't handle the current...
