11.05.2005, 02:54 AM
OK,i got mine solved,to a large extent,still not perfectly free.Basically it was binding really bad when i tightened the top half of the case(top 3 screws) both as a 2- speed and the g-maxx single speed.Basically the top shaft bearings are too close together ie. they didn't quite mill the bearing holes deep enough.I think 4mm bearings might be an easy fix but i ended up grinding down a top gear tonight to test the theory and it's much better than before.My top shaft's not running true now though for some reason,vibrates if you spin the tranny with a drill.I'll have another go tomorrow.
