lutach
lutach's Avatar
10.11.2008, 11:43 AM
Originally Posted by phatmonk View Post
Yea ya cant go wrong with the Neu line of motors I happen to have 3 of them.Is there any mods Lutach that can be done to these motors to add durability?And when you say simular were yours the exact motor?This is a 2770 kv the end bell is bolted on and the shaft is keyed also the magnet strength resembles the original Neus not the current easier turning models.This particular motor is longer and has a larger diameter than my Neu 1515/1.5d/f motor.I am gonna take it aprt to inspect the inside.
If common sense was so common everyone would have it
I don't think an mods will help these motors. I was thinking of a nice little water cooling system, but that would just add more weight. The ones I bought from Hobbycity were made by the same factory Keda (Hance the KD on the Hobbycity ones). One thing to make sure is to use Loctite on the screwed on front end and also on the screws at the rear end. Most high quality 2 pole motor designs don't have that strong of cogging to them. You should see how smooth Lehners and Hackers are when you turn them.
