CRTIM
10.11.2008, 02:09 PM
Originally Posted by cheesecake View Post
yup the 13x16 shims space the diff out. did you trim down the hotbodies pinion? if not the smaller shims are used to shim out the center shaft on the pinion
ok thanks for the help ...yes,i did trim the pinion shafts,so all is good there....i tried to put 3 shims on the ring side and 1 on the other but was very notchey feeling and loud (compared to the stock CRT gears,which were very smooth and quiet ) so i tried 2 and 2 ,and seems a little smoother...could i have set them up wrong using 2 shims on each side ?...also i didn't use any shim on the pinion...thanks again for the help
