Unsullied_Spy
Unsullied_Spy's Avatar
10.12.2008, 11:32 AM
Originally Posted by cheesecake View Post
well i dont think the gear will fit due to no cutout on the buggy chassis
That's easy enough to fix though. Use a Sharpie to mark out on the chassis where the hole is needed, then drill holes in it with a regular drill bit about the right size, then use a cutoff wheel on a Dremel to cut it all out (there shouldn't be a whole lot if you drilled it right), then just clean it all up with a grinding bit on the Dremel. Take your time to do it right and it will come out nice and probably still only take 30-45 minutes.
