stum
10.13.2008, 02:25 PM
Originally Posted by starscream View Post
To each their own but I tried the elektriclutch as well and direct drive is much better. The clutch acts somewhat like a slipper and reduce the current draw from your motor but eliminates most of the other advantages of an electric system (brakes & instant power). I'm also not really a fan of metal to metal pinion and spur. Metal to metal is fine in a sealed static transmission but not good where chassis flex is involved.
You'd be served well using between a 16-18T pinion and 51T spur.
I sold my 8ight-e a while ago but I still have an aluminum spur adapter for the 8ight that fits the ofna 51t plastic spur.
PM me if your interested.
Power is still pretty instant with the clutch, it just takes slight edge off when you take off and lets you have better traction, effectively making you faster which is exactly why it works so well on dirt race tracks. Again at times slower is faster.. expecially racing. If I were on carpet or asphalt I would go w/ the pinion to drive. PS this system is using mechanical brakes.. Which is a ton better than motor braking, not only for the motor and esc but it allows much better adjustment including front to rear.
