stum
10.13.2008, 08:17 PM
Originally Posted by bensf View Post
You should measure how much energy is in a battery using this formula. Ah x V = how much energy there is. (Watt/hours)
4S 5Ah
and 5S 4Ah have exactly the same amount of stored energy.
Are you saying that a 20s 8k pack has the same amount of energy as a 2s 8k pack?
It's not that simple boss.. a 20s 8k pack would not only be impractical in RC the weight would be ~1480grams vs ~365ish.. I could outrace you with any 1:8 setup me on 2s 8k and you with 8s 8k :P I can imagine how efficient your truggy/buggy would be with that much added weight :P don't forget about the wind resistance calculation for a brick that size and the balance issue you now have and the fact you can't hit any jumps, or at least land them.. lol :) how much did that ESC cost to run it?
And as noted above it has a lot to do with where the motors peak effeciency is as well if you are under the 30k rpms or way over it you will have negative effect to calculate as well.
mAH = gas tank, AMP rating (c rating) = fuel line, Voltage = Octane
You have some cars capable of 40mpg, while some only do 12mpg on the same size tank, you have slightly better operation and mileage with higher octane fuel vs low grade in the same car but if you burn too hot you can destroy the motor at the same time, you can't take the car that does 40mpg and expect 100mph but the car that can do 100mph won't get you 40mpg.
Same with rc's and setups.. way more to calculate than a simple 'same amount of energy' statement and that isn't even true, as you have to factor in the batteries capable amp draw not just voltage x mAH, you have to use your mAH and c rating to figure out amp draw and multiply the amp draw by your voltage to get a usable watt/hour (as I did above). And that doesn't even start to tell you which is going to be more effecient with out looking at all the other items. The fact that you can do over 45 w/o heat issues tells me your motor has a slightly higher kv rating, thus more than enough RPM's to not have to worry much about the little votlage from 4s to 5s, again this was a change to speed up your lap times.. and get you beyond 20minutes. I have raced 20minute mains w/ my 4s 5k 30c packs w/o any issues with a few warm up laps to boot, no 50% chance of not making it.. lol.
EDIT: YA know.. I just noticed you have a 2.5d reading back, and only geared for 43.. I was reading two different configs and lost track, for some reason I thought you had the 1.5d (2700kv) and were pumping it w/ 5s.. hehe my bad on that end and it will change how effecient it is, with a the 2.5d you will be at a fairly low RPM on 4s, usable as I race the 2.5d on my erevo truck now geared for about 40 on a 4s config and it's perfect (I have run a 20min main w/ it as well). Took 3rd in the last a-main of the year behind the two local pro's (pro series pro's).
So ya with that low of RPM you'll want to stick w/ 5s and gear down, heh :) I'll just shut up now :P
