Originally Posted by bdebde
I notice mine gets quite hot when trying to discharge so I don't do it with that charger.
Hmm.. I do have another charger, but it will only facilitate 15 cells at a time. I would have to revert to single pack discharging.
Originally Posted by wallot
I would check the fan, it might be worn out, dusty. never had any temp issues with my old 989.
I'll check the fan later tonight... To be honest, the fan on the power supply was filthy
and I had to remove it and clean it before use.
Thanks for suggestion wallot.
Originally Posted by BrianG
12 cells at 2A is ~24 watts. It's gonna get warm. My Hyperion EOS 7i does that too - gotta remember it is converting all that energy to pure heat. Also, you might be hitting a power limit. My Hyperion has a 20w limit, so the higher cell counts I go, the less current it will discharge at.
do you have any recommendations Brain? like a basic setup for discharging and charging... I am currently running 3 sets of 16 cell packs and a 12 cell pack (all have cycled up to an average of 3200 mah)
Thanks for the quick response guys...
Alien
