10.15.2008, 05:41 PM
Ah, you have a Strobe slipper, that explains it. Yeah, if you flip the tranny around, then switch a couple motor > esc wires around, the truck will still travel forwards when you pull the throttle, but the nut on the slipper wont undo as the gears are spinning the opposite direction to before.
