gramey
gramey's Avatar
10.17.2008, 06:29 PM
Originally Posted by Devilmanak View Post
If you want to ram 4mm x 16mm screws into a hole designed for 8/32" x 1/2" then have at it. In mm a 4mm screw is actually 3.8-3.9mm, depending on brand. An 8/32 is 4.04 +/- depending on brand. May not seem like a lot until you hold the screws side by side. It is NOT the correct way to build a car.
The chassis has 20 8/32 holes in it, not 12.
It also has 20-22 smaller 5/64 sized holes in it. All of those are countersunk for metric hardware also.
Losi would not send out a product like this as you have stated.
This is not a cosmetic issue in any way. If we use 4mm fasteners then the plastic Losi parts are damaged for future use, and they do strip using the holes. (I started assembly per your recommendations, the third one stripped.) Besides the fact that we now have a car with metric and standard fasteners.
If we use the correct hardware for the car we are working on, the heads stick out of the chassis up to 1/16 of an inch and the strength of the fasteners is compromised due to the tapers being incorrect.
Lots of people do lots of things that "work". That doesn't make it right. unfortunately in this hobby, many enthusiasts don't know any better, so when a company tells them to do something to cover their own mistake, the people believe it. People don't know better to stand up for themselves. Or they know that complaining will get them nowhere, as this last post has proven.
If Tekno truly cared about their customers, they would send out 82 degree countersinks wrapped in a $20 bill to cover our time to fix a product that never should have been sold to begin with.
Whilst it's frustrating that these chassis's were countersunk incorrectly I really do think your making a mountain out of a mole hill. Personally it's not a question of not knowing any better as you suggest but being pragmatic. I haven't had one RC kit that doesn't need modding in some way to resolve minor issues that obviously weren't apparent at the time of manufacture, this includes, 1/10th, 1/8th, 1/5th cars and my heli's. Losi aren't immune to this either, everyone knows there's a problem with the CVD pins falling out but you have to buy a third parties upgrade part to fix it, the rear hinge pins on the 8T are made of cheese and I've had to fit the Mugen ones to get over that.
If you don't like changing the screws out for metric, which I personally prefer as US manufacturers are the only ones still using imperial, treat yourself to a countersink and chill out.
Losi 8T RR - Novarossi Plus 21-5BT/ Jammin JP3 - Teknorc 8T - Neu 1515-1Y - MGM 16025-3 Z Series ESC.
