10.17.2008, 11:04 PM
The outrunner will (hopefully) directly replace the differential without too many issues/modifications. The motor shaft will come out both sides equally, and I'll probably have bearings supporting them. The shaft will mount into the CVD joint right where the differential shaft would've gone. Steering will not change at all from the stock setup.
