10.18.2008, 02:50 AM
So I take it you would need a UBEC to power it? How many recievers can you feed 2s LiPo (8.4V off the charger) into without frying them? I know the Spektrums can handle 9V, IDK about others. I also don't know of any ESC that has a 7.4V option for it's internal BEC.
The price looks pretty good for something of this calibre.
You can always wire the servo directly to a 2s lipo (with a lvc between), and power the receiver with the esc bec. Or buy a ccbec and set it for 7.2v and wire the output to the servo directly.
I did this with my friends axial crawler. He runs a tower pro 995 and we are running it on 7v thru a ccbec, and running the rec with the sidewinder internal bec. Just pull the signal wire off the servo, and plug it into the reciever, then wire the pos and neg of the ccbec output to the pos and neg of the servo... He must have 10+ hours on it so far, and it is still working. Not bad for a $12 servo.
