SilveradoHD
10.18.2008, 06:11 PM
Using mismatched plugs could be a serious issue- either hard wire it or use the same sized male & female plugs. Sure its not in brushed mode or something?..
It is not in brushed mode, I just checked. I checked over all the wires today and they look fine. I tried another receiver, still no luck. I am going from the 6.5mm bullets at the speed controller to castle 5.5mm bullets to the motor because I couldn't find the 6.5mm bullets in stock anywhere. I was just touching the the VXL motor with the 3.5mm bullets into the 6.5mm bullets directly on the speed control to see if I could get any kind of tone or movement from in to see if I could eliminate my Medusa from the equation. When I hit the throttle, the LED turns green but also blinks yellow, same when I hit the brakes, red and yellow. Is this normal? I don't know whats wrong with this thing, but from changing trying another battery, another motor, and another receiver, I suspect the problem lies in the ESC. Just very strange that it still powers up and links through castle link.
