Originally Posted by SilveradoHD
It is recognized by Castle Link. I re calibrated it to my radio. It now turns green, yellow and red when moving the trigger but still no power. There is also no audible tone anymore. I put an old VXL motor in with the 3.5mm bullets into the 5.5mm bullets and nothing worked still. I also put the steering servo on channel 2 to verify it was working.
Sounds to me like the motor locked up.
As for the 2nd motor.... You need to get a proper connection if you want any hope of it working. Get rid of the mismatched plugs and direct solder it if you want to test it. It sounds like the esc is doing what its supposed to do, but the motors arent.
