Moving on up to the E-side....
portyansky
Moving on up to the E-side.... - 10.19.2008, 02:40 PM
Well after putting off this project for over a year, I have finally taken the plunge. Here is my Revo electric conversion.
Things used:
Tekno electric conversion
Medusa 60-2000kv
Monster Mamba V2
Here is how she looked before the conversion:
And a pic with the goods:
Now lets begin. First I had to take off the fuel tank, fuel tubbing, engine adjustment screws(reuse them later), throttle links and the right side box.
Now I had to build the electri-clutch, you use your original cb, shoes, flyweel etc. The adapter is what comes in the Tekno kit. It came together awesome, all it needed was one shim under the c-clip (which I may be changing to a screw, depending how it holds up).
Assembled:
After that step I was on to the motor brace.
Assembled:
Then I had to attach the motor mount (Depending what diameter can you have, you will be required to attach the mount upside down):
Assembled:
