11.07.2005, 11:44 AM
Hi,
I have experience with this same kit with the exception that I bought it from the US. As mentioned, it locks the truck in 1st gear. The kit comes with a 18T pinion. If you install the full kit, there is no need to retain the mechanical brake (can't anyway as the battery will interfere with the brake control linkage) as the special shaft replaces the one way device in the gear box.
I have run the truck with the conversion kit installed with a feigao 7XL & BK 9920 esc & it worked fine. The batteries used were Kokam 20C 3200mah 5S lipo.
Hyper 9e Medusa 4S, Savage 5S MMM 8XL, Jammin' 4S Neu MMM, X2 Ninja JX, X2 MMM 5S Neu, E REVO Medusa 6S
