10.20.2008, 08:46 AM
Its a simple fix Hardstyle. Just open the tranny up, hunt down any loose bits of pin that are inside the tranny, punch the remainder out of the shaft (if any), and then re-attach the gear to the shaft like I explained earlier. I found bits of pin stuck into the output gear that caused binding, so be sure to remove them and then re-grease the gears before putting it back together.
