Pdelcast
Pdelcast's Avatar
10.20.2008, 03:47 PM
Originally Posted by Sneaky Pete View Post
Well, Patrick beat me...
I sure hope that V3 firmware gets updated soon.
So, could you also comment, Patrick, on the clearance between the plugs on the motor side and the heat sink?
V3 software will be online either tonight or early tomorrow.
There is no issue with clearance between the plugs and the heat sink. We've tried every possible combination of short between the plugs and the heat sink, and it just doesn't cause any problems or issues. (usually it just ablates the aluminum and keeps right on going. -- in no case does an output short through the heat sink cause ESC failures.)
Patrick del Castillo
President, Principle Engineer
