RC-Monster Stainless Steel
10.20.2008, 11:21 PM
Originally Posted by Gee
Brian,
A suggestion for your already excellent web page. Don't know if you have time or think it would be worth the effort but never hurts to ask......
Maybe add an option to say your parameter solver or speed calculator that would pump out a table of what the est speed would be for say 10 different size pinions in increments of 1.
Don't know if I saying it correctly.
For example you would put all the info in for your RC on the est speed calc. Then instead of needing to go back and changing the pinion size from 10, 11, 12, etc. to see the different speed you would get. You could hit a button and it could display a table or something with the different speed you'd get for say a 10T - 20T pinion. It be cool then to go back and change the spur gear and see what the table would put out using the same pinions. Even on the reverse side say it would pump out the size pinion for estimated speeds of 30, 35, 45, 50, etc.
What do you think?
+1
