kvrc
10.21.2008, 09:42 AM
no matter where you end up gearing it at dont remove the fans unless you are running in very cool outside temps. i guess if it is around 55f or less where you are running it then i can see it not getting super hot. when you start running it on 80+ degree days you will have heat problems.
with my 6.5 system geared at 10/46 if either my esc or motor fan failed my system would thermal at no more than 8 minutes or so in racing conditions.
