Originally Posted by Tempted
You might give it a little while and try the Traxxas 750 motors in the Summit. They should be considerably cheaper than the stuff Kershaw sells and I think they will bolt up to a stock motor plate.
They might have a 25mm bolt pattern, but I think they have the 30mm pattern. Remember that the rear facing mount on the revo has both 25mm and 30mm bolt patterns. Plus most 700 motors use the 30mm pattern and also use m4 thread screws. I am sure that they are heavy buggers.
I will try the johnson motors I have. I will wire them in series first and run them on 4s lipo.
