ffactory666
10.21.2008, 07:03 PM
I'll let you know. I'm going to make a chassis for my TC3 that will allow 2 2S hard cased lipos to be used so I can wire them in parallel, so yes the weight will help you keep the car down. The 30C hard cased packs by Enerland will be plenty good. If you have 64P gears ditch them right now. I use 48P and if you're going to do speed runs use a 65T spur and the biggest pinion you can find, but you can basically use BrianG's calculator to give you an idea of what to gear the car for.
I will have to see if the Enerland 30c will fit the car? I don't have the car yet so i am waiting for guys to give me some measurements of what will fit in it .
Luci i ddin't think you could alter the chassis in the 2s speed scale class ? or is the TC3 for another use.
I am using a 48p 72T spur , couldn't find any smaller in 48p and will start with pinions from 22t - 26t as that's what i have at the moment , should get me going for now .
