Thread: Crawler
coolhandcountry
coolhandcountry's Avatar
11.08.2005, 08:50 AM
That could be very doible. Get a four channel radio with daul stick. Left be the foard back left and right for the front and the right one be the same for rear. That way you would pull the front end around some. You run the dual transfer case in a 1;1 for lower gearing. You run the dana 300 with twin stick for the difference in ratios. If this helps you. You can also do the np 205 trans fer case.
Peace!
Country
Help support the
Rc-Monster
Buy here
