lutach
lutach's Avatar
10.23.2008, 03:36 PM
Hey Luciano, got the esc in today. How do I go about hooking up the program card? Just plug the rec wire ito the slot on the card and also plug in a rx nimh pack into the card too? I see it has two areas to plug into. Also, do I have to have a pack plugged into the esc during programming?
Just plug the ESC's Rx plug and plug your pack to the esc and turn it on. It should power the program box and then you go through the settings that you need and press OK every time you change something before you jump to the other setting. You can also plug an Rx pack, but it's only needed when the ESC's BEC is disabled. I can make a quick video if you need .
