10.23.2008, 04:46 PM
Just plug the ESC's Rx plug and plug your pack to the esc and turn it on. It should power the program box and then you go through the settings that you need and press OK every time you change something before you jump to the other setting. You can also plug an Rx pack, but it's only needed when the ESC's BEC is disabled. I can make a quick video if you need .
Ok, got it, thanks!
