cdis
10.24.2008, 12:06 PM
I think that Wanderer is the same as my Feigao 8XL which is 2084kv. If it's the same motor, just rebadged, the max RPM is 30,000. I think the newer ones come with 50,000 max RPM bearings, but I'm not sure. With 6S A123 you'll be wayy over that. That's the other reason I was running a 4S A123 setup - I found the 5S was making the motor seriously hot.
If you want tho, you might consider swapping out the bearings in the wander to these, which are rated to 70k RPM. I was going to do it, but I figure the motor will be more inefficient than a Medusa anyway, so I may as well just get the Medusa lol.
