10.24.2008, 02:59 PM
My v3 fan wire looked very similar. I also noticed that one onf the rasided edges of the bottom case needs to be clearanced a bit as it appears to be trapping the fan wire between inteslf and the board. I put a bit of small heatshrink on the fan wire of my ve and had issues getting it back in the case... I would almost say to run the wire outside of the case and bring it back in where the signal wires exit (that slot needs to be bigger on the case too.) I will try that on my v3 before I run it...
I have decided that my v3 is going in my hyper8 buggy with a 1900kv aveox on 6s lipo. Going to run the new case and just re-route the fan wire. Only mods that I will do. Hope it survives...
