10.24.2008, 05:52 PM
the wing is a lighting 10 wing its 6.75 inches wide the crt.5 wings are 5.5 inches wide i think, but yes it fits nicelys and is 100x better than the lexan 1/10th scale wings. im looking at trying a crt.5 wing but i dunno if itll be too narrow or not and look funny. we need to find a 6-6.25 inch wide hard wing.
my bad they are not all xray bearings... the diffs and center shaft is all on xray bearing (youll have to search each size you need on amain) and all the wheel bearings are from advantage racing, they are the inner sheilded outter sealed bearings and are about the best i have found (you obviusly put the shields to the inside and rubber to the outside.)
we actaully havent broken anyhting other than MELTing a plastic diff outdrive due to the bearing locking up and ruinng a couple spurs but we havent had any of those since we got the undertray......ill just replace as i go but for how well these stock plastic pieces are holding up i doubt ill upgrade if they break, but just replace them....plus im not really bashing this thing around and it drives so well on the track im not rough at all on it. cant wait till the lipo get here for it and i might try a vxl motor on it if i can get brad's now that he got his MM's back from castle for his b44 and lazer.... it ran GOOD in the b44 on 2s.
takedown the x11 looks cool but i couldnt spend that much i have less than 380 in this buggy, that with all the hopups, brushless, lipo and servo.
