MetalMan
MetalMan's Avatar
10.26.2008, 01:36 AM
You've probably seen my hybrid electric/mechanical brake setup. This is a lighter weight solution that enables me to have front/rear brake bias on the fly through the 3rd channel on my radio. This setup helps when cornering because where regular motor brakes cause the vehicle to push mine will pivot around the rear end better.
