Originally Posted by Pdelcast
I think we need less power -- our test motor for high power testing was a Neu 1521/1D -- on 6S.  NEVER TRY THAT AT HOME. I'M SERIOUS.
We broke so many transmission and gearing parts -- seems every run we would get 2-3 passes and then something in the drive train would fail.
Ahh, I see. Figured that crashes were causing the damage. A 2900kv motor on 6s sounds like fun. What vehicles were you using? I plan to use a 1521 1y on 6s in an erevo.... I doubt I will be as harsh as you guys due to the fact I am not trying to test the motor limits! But I am sure that you can tell me if the erevo will hold up?
Thanks for fixing the MMM Patrick, best esc out there.
