Thread: My Gmaxx build
George16
Supermaxx
George16's Avatar
10.27.2008, 02:03 AM
If you are running a neu, adjust the timing to MID. That cured my hesitation problems.
The timing is set at mid. I think the cogging was due to the LVC kicking in. I charge the batteries last night and prior to charging, I noticed the voltage to be at 10.45V. I set the LVC cutoff at 19.2V.
Originally Posted by TDC57
WOW that's some mighty nice soldering SIR.. I whish i could do that...
Thanks Shaun. Video won't be until this weekend once my son decides to go out with me. I just soldered the other pair of caps killajb sent to me and I plan on installing it on the MMM. Has anybody installed caps on the V3 yet?
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
