hoovhartid
Monster Bottle Opener
hoovhartid's Avatar
10.27.2008, 02:56 PM
Hoov,couple questions. How long did you run each setup? 4s about 35 minutes before the V2 failed. The 6s I ran for about the same on the first run and then about 30 minutes on the second. The temp ranges given,were they taken at different times,or different spots on the components? Yes, I temped the components at different times throughout the runs, but always took their hottest spot as the total temp, never an average. IOW is that the temps they leveled out at,which both seem fine.With the 4s did you have those temps at lvc? Never got that far, so no. The MMMv2 died before reaching LVC. That seems a little high,my SPC's usually stay around 5 degrees warmer then the ambient,but I rarely run them to lvc.1 more thing,where are you getting your speed estimates? i am using BrianG's speed calc. Since My Medusa 2000 runs 44 with 24/68 gearing,on 4s, What tires are you using?, To get those speeds on BrianG's calc, you need to balloon out to like 8 inches! I'm wondering what the 2 setups would radar at. Me too, but I dont have a radar. Are you running LPR tires? This is a good question, because I forgot to mention something important. On the 4s I was using badlands on LPR rims, on 6s I was using Crimefighters on LPR rims. I think that the badlands may have been holding more clay and retaining more weight than the crimefighters....which would have effected the temps. I'll do more runs on 4s now that my MMMv3 is here. I'll try to have less variables to give a better compairison.
<a href=http://i87.photobucket.com/albums/k137/darrajsam/bottomline.jpg target=_blank>http://i87.photobucket.com/albums/k1...bottomline.jpg</a>
I used a "bottom" line.
