chadr
10.27.2008, 11:01 PM
Originally Posted by 1maxdude View Post
try disabling your punch control if you can stand it, and put your start power to high. See if your temps come down after a pack or two.
I would think both of these would run more amps to the motor why should it bring down the temps?
Today I tried a few different gears at the track to see which one would get to 200 the quickest. All testing done with 90t spur and motor starting temp was 130 after my warmup laps.
19t - got to 195 within about 10 minutes. Seemed easier to pull the wheels up on the straight away when not really trying. Plenty of acceleration and speed. esc got to 145
16t - took a bit longer, but still got close to 200 in under 15 minutes. Still plenty fast for the track, feels perfect. This gearing gets me about 40 mph on the street. esc at 130+
13t - didn't get above 180 after 10 minutes then I called it a day. Fast enough but yet slow enough for easy control on the straight. The 16t and 19t are just enough speed to make it a bit difficult for full throttle. esc at 130 or less
I like the aluminum transmission option so maybe will try to get a deal on one of those. Today I got the vxl motor and installed the 19t so it should be just a tad faster than the 4600.
3500 * 9.9 * 19 = 658350 teeth per minute
4600 * 9.9 * 13 = 592020 teeth per minute
I hope the temps stay down so I don't need to spend $40 on an aluminum transmission case.
