ffactory666
10.29.2008, 05:00 AM
Originally Posted by DRIFT_BUGGY View Post
Well put the 14T pinion in and after 15 minutes the temps of the ESC was 140F and the motor 185F. I then set the punch control back to 50% and put the 13t pinion back in and after another 15 minutes which is when the lvc kicked in the temps were 130F for the esc and 175F on the motor. I'll hopefully get a chance to run another battery and check the temps again. Surely the thicker diff fluids aren't making the motor run hotter. I only went 2000wt thicker in the front and 1000wt thicker in the rear
Never heard of diff fluids doing that .
It's getting hotter in Melbourne and was 28 today my temps went up about 10 degrees across the board from last run but all well within acceptable temps .
I run medium timing on my Medusa as i was told by others and Medusa recommends medium timing on 4 pole motors so maybe you can try that.
Check your bearings in the motor as well and your whole driveline as something could be binding .
With AKA couldn't find any in OZ either ,A Main is the best bet or Imapkt ( i do most of my business with them as well )or try ebay for a bargain . Kyosho MP9 comes standard with medium compound City Blocks so look for one that is being parted , there a few at the moment
