10.30.2008, 02:24 AM
I think if you get some 7" MGT tires stairs wont be an issue. So you are having somebody make you a mid-bulkhead?
7" may be a bit too tall unless I run a lower kv motor...
I found a generic al bulkhead on ebay that is completely solid where the bumper mounts go. I will trim it is necessary and tap it for the chassis mount screws. I should also be able to use another collar on the rear, my current design does not have room for the collar. When I get the al mounts made I will post up a pic or two. Quite simple what I did, just need a complete metal bulk to make it more simple.
I plan to make another 6x6, but this one will be more like the truck stop racing truck. It will be much more powerful and faster. I will have to get a pass thru diff case made to accomodate 1/8 gears. My current diff will most likely not hold up to a kb 45 motor on 6s... Or a 1521.
