11.10.2005, 01:13 PM
I doubt it. It must be a very tight and alligned hole in order for the bearing to work correct. If the hole isn't 100% circlylar(sp?) the wheel can wobble badle and you will blow allot of bearing's. Not worth trying. Unless you know some machine shop you can ask them to do it for you.
