castlemike
10.30.2008, 11:40 AM
Originally Posted by bustitup View Post
Will do sir....you guys are the greatest
can a mod please change the title of this thread to "I killed it"......I would say its my fault also but you would think if the esc only got to 170deg. that it should have lived?
Not sure how you was getting the temp readings, but if you was reading 170 outside the case it was probably way over that for actual temp. Still should not have failed for that reason though. I would guess the overstressed batteries were more the factor then anything else. Send it in and I'll figure out what failed on it and get you fixed back up.
