NickRummy
NickRummy's Avatar
10.30.2008, 03:05 PM
Very cool project! should be fun to crawler over stuff with.
I have a feeling that it won't turn well even with the front and rear steering unless you are on some loose terrain. That center diff being locked is RIGHT in the middle of the rig so in the turn each wheel will be wanting to go in different direction. I have a feeling it's going to be hard to overcome the traction that middle axle is going to create.
How rigid is the center section? Is there a lot of flex in the middle if you pick up one end?
Can't wait to see this thing run!
